Hi
Posted: Sun Aug 03, 2008 10:40 am
by dynamix
Just thought I would pop by and say hi.
Currently investigating ecus for my 2006 DBW Impreza Sti and from what Pat says this seems to fit the bill.
I cant seem to see any pricing details though or info regarding how straightforward the ecu swap would be. Is a PnP option available for this car to use existing ecu wiring/sensors?
Re: Hi
Posted: Mon Aug 04, 2008 10:24 am
by pat
It's on the "to be validated" list. What that means is that fundamentally it should work, will be supported as a PnP version, but the wiring schedule is awaiting final validation. This step is necessary due to errors in the OEM wiring diagrams. If you look at MY92 Subaru they list ignition outputs in firing sequence rather than cylinder sequence, whereas injectors are listed in cylinder sequence. If you look at MY97 Subaru the MAP sensor is completely missing from the pinout, as is the Intercooler Water Spray. If you look at MY01 you see impossible pins; something is listed as being on pin 23 of a 16 pin connector if memory serves!
Until an MY06 DBW car has been run on an S6GP it is impossible to tell whether Subaru's wiring diagrams are indeed correct, and therefore it would be foolish to base a vehicle interface board on that wiring diagram! MY06- DBW OEM connectors are in the post, and it won't take long to make a test loom adapter to run an S6GP. S6PnP for MY06-07 DBW should be available within 8 weeks or thereabouts.
Re: Hi
Posted: Mon Aug 04, 2008 1:18 pm
by Charlie
Retail price of the S6 PnP is £1199 with the basic knock control included.
S6 GP Retail price is £1249 again with basic knock control included.
Full knock control option on the S6 is £125. (this is the only option on our ecu's. Every other feature we advertise is included in the price!)
S4C Retail is £1399.
S8C Retail is £2499 (full knock included)
All prices ex VAT.
Re: Hi
Posted: Fri Aug 08, 2008 10:44 am
by dynamix
pat wrote:Is a PnP option available for this car to use existing ecu wiring/sensors?
Pat - if you need a guinea pig .....
OEM Pin out diagrams are wrong unless you can get hold of the motec ones which are correct from what I have seen.
Re: Hi
Posted: Sat Aug 09, 2008 12:26 pm
by pat
Might just take you up on that
FWIW, the DBW throttle has now been tested and a set of control parameters that get a slightly underdamped response to step inputs but that track "normal" pedal travel dynamics with critical damping are on file, albeit they were tested on a throttle body off a vehicle and thus would not be affected by manifold vacuum / pressure, so it WILL need additional setup time on a live engine.
Regards,
Re: Hi
Posted: Fri Aug 15, 2008 8:49 am
by dynamix
Is there a similar mechanism to the OE requested torque (accel angle vs rpm) and throttle plate vs requested torque tables?
I am off now for a week over to the 'ring but definitely will speak when I return - thanks.
Re: Hi
Posted: Sat Aug 16, 2008 4:05 pm
by Jasper K
Hi Duncan!!
I see you are roaming about on here as well. The requested torque tables in the OE ECU do exactly that. If you increase the requested torque you might not reach your target throttle plate angle anymore. I have tested this on a Forester which throttle was not opening completely. I initially thought I needed MORE requested torque to open the throttle but the effect was exactly the opposite. Hope this helps you.
Jasper.
PS. I'm going to open another thread now as I don't want to hijack yours
Re: Hi
Posted: Wed Sep 24, 2008 9:27 am
by dynamix
Any progress on this now Pat or should I chat with Paul?
