Latest Firmware Releases
Posted: Fri Jun 09, 2023 11:10 am
by Ryan.g
Version 1.25 is the first release of the CorollaGR Firmware
Please ensure you are using the Latest Ssuite software which has USB support -
Help on updating the firmware can found in the via this YouTube Help video -
https://www.youtube.com/watch?v=RuXkm_9gBRU
Firmware Version 1.25 -
www.syvecs.com/downloads/X4AWD_Corolla_1-25-1.enc
Re: Latest Firmware Releases
Posted: Fri Dec 15, 2023 5:21 am
by Ryan.g
Changes since 1.25.1:
* Added LatG Duty Adjustment
Firmware Version 1.27 -
www.syvecs.com/downloads/X4AWD_Corolla_1-27-1.enc
1.29 Firmware Release
Posted: Mon Apr 15, 2024 3:09 pm
by Ryan.g
Changes since 1.27.1:
* USB Datalogging
Firmware Version 1.29 -
https://www.syvecs.com/downloads/X4AWD_ ... 1-29-1.enc
Posted: Tue Apr 15, 2025 7:12 am
by Ryan.g
Changes since 1.29.1:
* Enable Load for Steering Angle Multiplier
* Option for AN1 to be BurnOut Switch or TransferCase Temp
* Transfer Case Temp Linearization and Limp
Firmware Version 1.34 -
https://www.syvecs.com/downloads/X4AWD_ ... 1-34-2.enc
Posted: Tue Jul 15, 2025 5:02 pm
by Ryan.g
Changes since 1.34.1:
* Added AWD Temp Diag CAN Stream for CANCHECKED Dash
Firmware Version 1.35 -
https://www.syvecs.com/downloads/X4AWD_ ... 1-35-2.enc
