Latest Firmware Releases
Posted: Tue Feb 21, 2023 11:59 am
by Ryan.g
This thread is for tracking the firmware builds of the AWD Audi MQB5 units. When a new release is available it will be added to the end of this thread.
Help on updating the firmware can found in the via this YouTube Help video -
https://www.youtube.com/watch?v=RuXkm_9gBRU
Any further Questions please E-mail
support@syvecs.co.uk or speak to your nearest dealer
Re: Latest Firmware Releases
Posted: Tue Feb 21, 2023 12:01 pm
by Ryan.g
Changes since 1.23.3:
Please ensure you are using the Latest Ssuite software which has USB support -
OLD BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/AWD_MQB4_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/X4AWD_MQB4_1-24-4.enc
1.25
Posted: Fri Apr 07, 2023 6:50 pm
by Ryan.g
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/AWD_MQB4_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/X4AWD_MQB4_1-25-1.enc
Posted: Fri Dec 15, 2023 5:13 am
by Ryan.g
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 -
https://www.syvecs.com/downloads/AWD_MQB4_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 -
https://www.syvecs.com/downloads/X4AWD_MQB4_1-27-1.enc
1.29 Firmware Release
Posted: Mon Apr 15, 2024 2:20 pm
by Ryan.g
* Only Awd Pressure is read from Hall input if Huracan or 991 AWD build
* USB Datalogging
* Programming fix
viewtopic.php?f=8&t=122
OLD BOARD - Firmware Version 1.29.1 -
https://www.syvecs.com/downloads/AWD_MQB4_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 -
https://www.syvecs.com/downloads/X4AWD_MQB4_1-29-1.enc
