The latest VAG MQB4 AWD Base map which matches the latest firmware can be found below in Attachments
MQB4 is only available on the X4 Hardware
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
Latest Base Map
Latest Base Map
- AwdBase_MQB4 1.24 X4.SC
- (55.78 KiB) Downloaded 1842 times
1.25
- AwdBase_MQB4 1.25 X4.SC
- (61.05 KiB) Downloaded 2057 times
Re: Latest Base Map
- AwdBase_MQB4 1.27 X4.SC
- (66.87 KiB) Downloaded 175 times
Re: Latest Base Map
The latest VAG MQB4 AWD Base map which matches the latest firmware 1.28 can be found below in Attachments
- AwdBase_MQB4 1.28 X4.SC
- (72.44 KiB) Not downloaded yet
