Learn Maps - committing to base maps?
Posted: Sun Nov 13, 2022 11:26 am
by beetos
Hi
Does anyone know if the 'learn' maps (For idle base duty, knock/cylinder trim, WG duty etc) can be committed to their respective base map or do they just exist as separate constantly changing maps? Other ECU's I have used allow you to commit to the base map and zero out the learn map, wondered if you can do this on the syvecs.
Re: Learn Maps - committing to base maps?
Posted: Wed Dec 14, 2022 6:19 pm
by Slowie
Hi
When you are viewing the actual learning correction map (e.g. Base Wastegate Control Duty Learning / Learned Correction 1) you can use the Learn menu (top right) to apply or reset the learned correction to the base map.
Posted: Wed Dec 21, 2022 10:49 am
by beetos
Thank you! I missed that feature.
Posted: Thu Mar 02, 2023 2:13 am
by klakling
You can use the Learn menu (top right) to apply or reset the learned correction to the base map.
After covit, my need to travel is also growing. I mostly use the map to locate the best direction for myself
classic games Spades
Posted: Sat Apr 18, 2026 8:48 am
by superedan
beetos wrote: Sun Nov 13, 2022 11:26 am
Hi
Melon Playground Game
Syvecs treats learning as an adaptive system rather than a calibration shortcut. The learned data is there to enhance performance on the fly, not to replace the need for proper base tuning.
