Firmware 1.4 of the 50Hz/100Hz GPS Module is attached below.
Please use the Syvecs Updater program to load the ENC file. Guide here http://www.syvecs.com/downloads/Syvecs_Updater.pdf
ENSURE the GPS is sealed again if using in harsh environments with a silicon based sealant
The 1.4 Firmware fixes the following issues:
* Added support for 100hz new hardware
* Signed issue fixed on heading
* Speed Jumping issue fixed when stationary at high altitudes
Latest Firmware Releases
1.5 Firmware
Firmware 1.5 of the 50Hz/100Hz GPS Module is attached below.
The 1.5 Firmware fixes the following issues:
* BugFix for 100hz IMU Data being 90deg out with New IC
- SyvecsGPS100hz Lat Long Fix.zip
- (18.24 KiB) Downloaded 1626 times
1.6 Firmware
Firmware 1.6 of the 50Hz/100Hz GPS Module is attached below.
The 1.6 Firmware fixes the following issues:
* Improvements for signal decoding in areas where sat data is limited
- SyvecsGPS.zip
- (18.4 KiB) Downloaded 43 times
