Latest Firmware Releases
The Syvecs WMI controller is a compact but very powerful unit for controlling a complete Water Injection electronics system, safely and correctly.
This thread is for tracking the firmware builds of the WMI Unit. When a new release is available it will be added to the end of this thread.
Help on updating the firmware can found here - http://www.syvecs.com/downloads/Syvecs_Updater.pdf
1.3 Firmware
This is the first public release level
Firmware Version 1.3 - www.syvecs.com/downloads/WMI_1-3-1.enc
1.5 Firmware
Version 1.5 contains the following updates
*Custom PWM Output 1 - Fully Renamable output with adjustable X and Y axis
*Custom PWM Output 2 - Fully Renamable output with adjustable X and Y axis
*Flow Limp Based on WmiFinalDuty
Firmware Version 1.5 - www.syvecs.com/downloads/WMI_1-5-1.enc
1.6.2 Firmware
Version 1.6 contains the following updates
*Bug Fix on Veh Speed conflict with OEM Can Frames
*Added Subura Impreza My2015+ CAN Support
*Added Suzuki CAN Support
Firmware Version 1.6 - www.syvecs.com/downloads/WMI_1-6-1.enc
Re: Latest Firmware Releases
Version 1.6.2 contains the following updates
*Added more OEM CAN Support
*HBR2A Monitoring BugFix
Firmware Version 1.6.2 - www.syvecs.com/downloads/WMI_1-6-2.enc
1.7
Version 1.7.1 contains the following updates
*Added LCD Control Maps for future hardware
*Added support for new X4 Board
*LimpMode Duty Multiplier bugfix
Firmware Version 1.7.1 - www.syvecs.com/downloads/WMI_1-7-1.enc
Version 1.8.1 contains the following updates
*Motec M1 Series Support
*EcuMaster Support
Firmware Version 1.8.1 - www.syvecs.com/downloads/WMI_1-8-1.enc
1.10 Firmware
Version 1.10.1 contains the following updates
* Generic CAN Receive Logic expanded which allows users to now set a ID, Endianness, Start bit, length, scaling, offset and signing.
* Added CAN support for Yamaha ECUs
* Added CAN support for LINKECUs
* Added CAN support for LandRover Defender 90 110
Firmware Version 1.10.1 for HBR WMI - www.syvecs.com/downloads/WMI_1-10-1.enc
Firmware Version 1.10.1 for X4 WMI - www.syvecs.com/downloads/X4WMI_1-10-1.enc
1.10.2 Firmware
Version 1.10.2 contains the following updates
* Aquamist Flow Sensor support on earlier HBR board
Firmware Version 1.10.2 for HBR WMI - www.syvecs.com/downloads/WMI_1-10-2.enc
Firmware Version 1.10.2 for X4 WMI - www.syvecs.com/downloads/X4WMI_1-10-2.enc
1.10.3
Version 1.10.3 contains the following updates
* BugFix for FuelDuty CAN Pickup
Firmware Version 1.10.3 for HBR WMI - www.syvecs.com/downloads/WMI_1-10-3.enc
Firmware Version 1.10.3 for X4 WMI - www.syvecs.com/downloads/X4WMI_1-10-3.enc
Locked
