Lambda issue
Posted: Tue Feb 01, 2022 11:00 am
I have a s7 plus ecu the lambda readings fluctuate while sensor plugged in the voltage jumps around all over the place. I tried 3 sensors same results . I even pinned 6 wires direct from ecu to the sensor and same issue. Has anyone come across this issue? Could it be the ecu internal Wideband controller fault?
