Latest Base Maps
Latest Base Maps
For use with 1.21 Firmware
- AwdBase_YarisGR 1.21.SC
- (46.26 KiB) Downloaded 2116 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_YarisGR 1.23.SC
- (51.46 KiB) Downloaded 2020 times
- AwdBase_YarisGR 1.23 X4.SC
- (51.46 KiB) Downloaded 2045 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_YarisGR 1.24.SC
- (55.83 KiB) Downloaded 2017 times
- AwdBase_YarisGR 1.24 X4.SC
- (55.78 KiB) Downloaded 1982 times
1.25
- AwdBase_YarisGR 1.25 X4.SC
- (61.05 KiB) Downloaded 2195 times
Re: Latest Base Maps
For use with 1.27 Firmwares
- AwdBase_YarisGR 1.27.SC
- (66.84 KiB) Downloaded 321 times
- AwdBase_YarisGR 1.27 X4.SC
- (66.87 KiB) Downloaded 319 times
- AwdBase_YarisGR 1.28 X4.SC
- (72.44 KiB) Downloaded 6 times
1.29 Base map
- AwdBase_YarisGR 1.29 X4.SC
- (72.89 KiB) Downloaded 5 times
