Latest Base Map
Technical Help / Firmwares for the Porsche 991.1 / 991.2 Awd Controllers
Latest Base Map
The latest Porsche 991 AWD Base map which matches the latest firmware can be found below in Attachments
AwdBase_991 1.14.SC
(37.21 KiB) Downloaded 2146 times
1.15
1.15 Firmware base maps
AwdBase_991 1.15.SC
(41.62 KiB) Downloaded 2096 times
1.18
AwdBase_991 1.18.SC
(42.89 KiB) Downloaded 2131 times
1.21 Base Map
For use with 1.21 Firmware
AwdBase_991 1.21.SC
(46.26 KiB) Downloaded 2084 times
1.23 Base Maps
For use with 1.23 Firmwares
AwdBase_991 1.23 X4.SC
(51.46 KiB) Downloaded 1955 times
AwdBase_991 1.23.SC
(51.46 KiB) Downloaded 1974 times
1.24 Base Maps
For use with 1.24 Firmwares
AwdBase_991 1.24 X4.SC
(55.78 KiB) Downloaded 1985 times
AwdBase_991 1.24.SC
(55.83 KiB) Downloaded 1987 times
1.25
AwdBase_991 1.25 X4.SC
(61.05 KiB) Downloaded 1968 times
Re: Latest Base Map
For use with 1.27 Firmwares
AwdBase_991 1.27 X4.SC
(66.87 KiB) Downloaded 179 times
AwdBase_991 1.27.SC
(66.84 KiB) Downloaded 169 times
Re: Latest Base Map
For use with 1.28 Firmwares
AwdBase_991 1.28 X4.SC
(72.44 KiB) Downloaded 3 times
Re: Latest Base Map
1.29 Base map
AwdBase_991 1.29 X4.SC
(72.89 KiB) Downloaded 2 times
