The latest Porsche 991 AWD Base map which matches the latest firmware can be found below in Attachments
Latest Base Map
Latest Base Map
- AwdBase_991 1.14.SC
- (37.21 KiB) Downloaded 2201 times
1.18
- AwdBase_991 1.18.SC
- (42.89 KiB) Downloaded 2182 times
1.21 Base Map
For use with 1.21 Firmware
- AwdBase_991 1.21.SC
- (46.26 KiB) Downloaded 2124 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_991 1.23 X4.SC
- (51.46 KiB) Downloaded 1999 times
- AwdBase_991 1.23.SC
- (51.46 KiB) Downloaded 2015 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_991 1.24 X4.SC
- (55.78 KiB) Downloaded 2037 times
- AwdBase_991 1.24.SC
- (55.83 KiB) Downloaded 2025 times
1.25
- AwdBase_991 1.25 X4.SC
- (61.05 KiB) Downloaded 2010 times
Re: Latest Base Map
For use with 1.27 Firmwares
- AwdBase_991 1.27 X4.SC
- (66.87 KiB) Downloaded 207 times
- AwdBase_991 1.27.SC
- (66.84 KiB) Downloaded 195 times
Re: Latest Base Map
For use with 1.28 Firmwares
- AwdBase_991 1.28 X4.SC
- (72.44 KiB) Downloaded 7 times
