The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
Latest Base Map
Latest Base Map
- AwdBase_RS3 1.14.SC
- (37.21 KiB) Downloaded 2312 times
1.18
- AwdBase_RS3 1.18.SC
- (42.89 KiB) Downloaded 2022 times
1.21 Base Map
For use with 1.21 Firmware
- AwdBase_RS3 1.21.SC
- (46.26 KiB) Downloaded 2151 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_RS3 1.23.SC
- (51.46 KiB) Downloaded 2027 times
- AwdBase_RS3 1.23 X4.SC
- (51.46 KiB) Downloaded 2025 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_RS3 1.24.SC
- (55.83 KiB) Downloaded 1935 times
- AwdBase_RS3 1.24 X4.SC
- (55.78 KiB) Downloaded 2060 times
1.25
- AwdBase_RS3 1.25 X4.SC
- (61.05 KiB) Downloaded 2023 times
Re: Latest Base Map
For use with 1.27 Firmwares
- AwdBase_RS3 1.27.SC
- (66.84 KiB) Downloaded 232 times
- AwdBase_RS3 1.27 X4.SC
- (66.87 KiB) Downloaded 235 times
Re: Latest Base Map
For use with 1.28 Firmwares
- AwdBase_RS3 1.28 X4.SC
- (72.44 KiB) Downloaded 3 times
Re: Latest Base Map
For use with 1.29 Firmwares
- AwdBase_RS3 1.29 X4.SC
- (72.89 KiB) Not downloaded yet
