Latest Base Map
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
Ryan.g
Syvecs Staff - Caretaker
Latest Base Map
Post by Ryan.g »
The latest VAG MQB AWD Base map which matches the latest firmware can be found below in Attachments
This base map limits the Max duty to 70%, Some users of the Rs3 Kit from Iroz motorsport have the duty limits at 80% or even 90%. You will need to adjust in Scal to Suit
AwdBase_RS3 1.14.SC
(37.21 KiB) Downloaded 2378 times
Ryan.g
1.15
Post by Ryan.g »
1.15 Firmware Base Map
AwdBase_RS3 1.15.SC
(38.8 KiB) Downloaded 2237 times
Ryan.g
1.18
Post by Ryan.g »
AwdBase_RS3 1.18.SC
(42.89 KiB) Downloaded 2081 times
Ryan.g
1.21 Base Map
Post by Ryan.g »
For use with 1.21 Firmware
AwdBase_RS3 1.21.SC
(46.26 KiB) Downloaded 2214 times
Ryan.g
1.23 Base Maps
Post by Ryan.g »
For use with 1.23 Firmwares
AwdBase_RS3 1.23.SC
(51.46 KiB) Downloaded 2096 times
AwdBase_RS3 1.23 X4.SC
(51.46 KiB) Downloaded 2088 times
Ryan.g
1.24 Base Maps
Post by Ryan.g »
For use with 1.24 Firmwares
AwdBase_RS3 1.24.SC
(55.83 KiB) Downloaded 1991 times
AwdBase_RS3 1.24 X4.SC
(55.78 KiB) Downloaded 2116 times
Ryan.g
1.25
Post by Ryan.g »
AwdBase_RS3 1.25 X4.SC
(61.05 KiB) Downloaded 2095 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
For use with 1.27 Firmwares
AwdBase_RS3 1.27.SC
(66.84 KiB) Downloaded 281 times
AwdBase_RS3 1.27 X4.SC
(66.87 KiB) Downloaded 284 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
For use with 1.28 Firmwares
AwdBase_RS3 1.28 X4.SC
(72.44 KiB) Downloaded 10 times
Ryan.g
Re: Latest Base Map
Post by Ryan.g »
For use with 1.29 Firmwares
AwdBase_RS3 1.29 X4.SC
(72.89 KiB) Downloaded 9 times
