Latest Firmware Releases
Re: Latest Firmware Releases
Hello, I have a huracan 610-4 and am trying to develop a good calibration so I can launch with low 60 foot numbers and not spin . Is there a calibration that you guys have put together that I can work off of ? I am new to exotic tuning and am quite lost on how to calibrate with scal. What should I be changing to get nice solid launches on street tires ? I recently changed my tire size from 305/30/20 to 345/30/20 and I believe the calibrator is confused with that and leaves the car extremely wobbly on top end . If you can send a video or instructions that would be great. Also, can I just save a file that allows me to dyno my car on a rwd roller or do I have to change it every time ? Any info will be greatly appreciated as I am eager to learn how to dial this controller in.
1.25
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/AWD_HuracanR8_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 - www.syvecs.com/downloads/X4AWD_HuracanR8_1-25-1.enc
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/AWD_HuracanR8_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - www.syvecs.com/downloads/X4AWD_HuracanR8_1-27-1.enc
1.28 Firmware Release
Changes since 1.27.1:
* Usb Datalogging
* Only Awd Pressure is read from Hall input if Huracan or 991 AWD build
OLD BOARD - Firmware Version 1.28.1 - www.syvecs.com/downloads/AWD_HuracanR8_1-28-1.enc
NEW BOARD - Firmware Version 1.28.1 - www.syvecs.com/downloads/X4AWD_HuracanR8_1-28-1.enc
* Usb Datalogging
