Latest Firmware Releases
Technical Help / Firmwares for the Audi R8 Gen2 and Lamborghini Huracan Awd Controllers
This thread is for tracking the firmware builds of the AWD Huracan / R8 units. When a new release is available it will be added to the end of this thread.
1.14.2
This is the first public release level
Firmware Version 1.14.2 - www.syvecs.com/downloads/AWD_Huracan.enc
1.15
Version 1.15 contains the following updates
*Change Light Output Pin (HBR4)
*Drive ratio calculation for Gear detection on Manual Trans cars
*Enable Gear Detection from Drive Ratio option
*Change Light Min Speed
*Change Light RPM
*Change Light Min Tps
Firmware Version 1.15.2 - www.syvecs.com/downloads/AWD_HuracanR8.enc
15.3
Version 1.15.3 contains a background change to send out the paddle up can frame for autoshift with R8
www.syvecs.com/downloads/AWD_HuracanR8_153.enc
1.18 Firmware
Version 1.18 contains the following updates
Changes since 1.15
1.16 - Added CanLogging option - New software will be released soon which allows you to monitor and log the canbus via USB
1.17 - CarCode Map Added for 997 Platform
1.18 - Added simple Map locking and Restriction option. - Press C, F inside a map
Firmware Version 1.18 - www.syvecs.com/downloads/AWD_HuracanR8_1-18-1.enc
1.21 Firmware
Version 1.21 contains the following updates
Changes since 1.18
V1.19 Output Testing added
V1.21 Output mode on changelight output to Lowside, Yaris HandBrake disable test mode light on dash in Burnout, Gear displayed in breakpoint, MAP1 Multiplier, post shift Multiplier to help stop spin after drivetrain torque change
Firmware Version 1.21 - www.syvecs.com/downloads/AWD_HuracanR8_1-21-1.enc
