Page 1 of 2
Latest Firmware Releases
Posted: Thu Mar 11, 2021 8:37 am
by Ryan.g
This thread is for tracking the firmware builds of the AWD Porsche 991 units. When a new release is available it will be added to the end of this thread.
Help on updating the firmware can found in the via this YouTube Help video -
https://www.youtube.com/watch?v=RuXkm_9gBRU
Any further Questions please E-mail
support@syvecs.co.uk or speak to your nearest dealer
1.14.2
Posted: Thu Mar 11, 2021 9:41 am
by Ryan.g
This is the first public release level
Please ensure you are using the Latest Ssuite software which has USB support -
Firmware Version 1.14.2 -
www.syvecs.com/downloads/AWD_Porsche.enc
1.15
Posted: Tue Apr 27, 2021 2:14 pm
by Ryan.g
Version 1.15 contains the following updates
*Change Light Output Pin (HBR4)
*Drive ratio calculation for Gear detection on Manual Trans cars
*Enable Gear Detection from Drive Ratio option
*Change Light Min Speed
*Change Light RPM
*Change Light Min Tps
Firmware Version 1.15.2 -
www.syvecs.com/downloads/AWD_Porsche_991.enc
1.18 Firmware
Posted: Tue Oct 12, 2021 8:39 am
by Ryan.g
Changes since 1.15
1.18 - Added simple Map locking and Restriction option. - Press
C,
F inside a map
Firmware Version 1.18 -
www.syvecs.com/downloads/AWD_Porsche_991_1-18-1.enc
1.21 Firmware
Posted: Thu Nov 04, 2021 5:45 am
by Ryan.g
Changes since 1.18
V1.19 Output Testing added
Firmware Version 1.21 -
www.syvecs.com/downloads/AWD_Porsche_991_1-21-1.enc
1.23 Firmware - X4
Posted: Wed Jul 13, 2022 2:23 pm
by Ryan.g
Changes since 1.21:
OLD BOARD - Firmware Version 1.23 -
www.syvecs.com/downloads/AWD_Porsche_991_1-23-1.enc
NEW BOARD - Firmware Version 1.23 -
www.syvecs.com/downloads/X4AWD_Porsche_991_1-23-1.enc
1.23.3
Posted: Thu Aug 11, 2022 9:13 am
by Ryan.g
Changes since 1.23.1:
OLD BOARD - Firmware Version 1.23.3 -
www.syvecs.com/downloads/AWD_Porsche_991_1-23-3.enc
NEW BOARD - Firmware Version 1.23.3 -
www.syvecs.com/downloads/X4AWD_Porsche_991_1-23-3.enc
1.24
Posted: Fri Nov 25, 2022 12:08 pm
by Ryan.g
OLD BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/AWD_Porsche_991_1-24-4.enc
NEW BOARD - Firmware Version 1.24.4 -
www.syvecs.com/downloads/X4AWD_Porsche_991_1-24-4.enc
1.25
Posted: Fri Apr 07, 2023 6:54 pm
by Ryan.g
Changes since 1.24.4:
OLD BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/AWD_Porsche_991_1-25-1.enc
NEW BOARD - Firmware Version 1.25.1 -
www.syvecs.com/downloads/X4AWD_Porsche_991_1-25-1.enc
Re: Latest Firmware Releases
Posted: Fri Dec 15, 2023 5:16 am
by Ryan.g
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/AWD_Porsche_991_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 -
www.syvecs.com/downloads/X4AWD_Porsche_991_1-27-1.enc
