Page 1 of 2
				Shell V-Power Flex Fuel reading
				Posted: Wed Apr 10, 2019 12:10 am
				by johnfelstead
				What are people seeing as the fuel composition on the Flex fuel sensor when using Shell V-Power?
I am seeing 12.1, which with an ethanol content of max 5% for V-Power seems odd.
Is this normal?
				Re: Shell V-Power Flex Fuel reading
				Posted: Wed Apr 10, 2019 7:57 am
				by MiSTI
				I am seeing around 4,6% with our 100oct fuel in Austria, which should be around 5% too.
				Posted: Wed Apr 10, 2019 11:59 pm
				by johnfelstead
				That doesn't sound right for the one i am looking at then.
Anyone seen this before?
				Posted: Thu Apr 11, 2019 6:10 pm
				Havent there been threads before where people seen less than 85%...when using proper 85 race fuel ?
These sensors are not actually measuring ethanol content though and can be skewed by other factors....I guess as long as readings are consistent for the fuel you use, then it's ok ? If suddenly there is a large deviation..there is a problem ?
				Posted: Thu Apr 11, 2019 7:46 pm
				by johnfelstead
				It would not be a reliable sensor if you could get such large discrepancies between sensors, so i don't buy that as being the case stevie. It's too dangerous to have them being so far out of spec and with the millions out there in use, they wouldn't get away with it.
I read the threads you mention about various E85 fuel readings, and that looked far more a case of suppliers not providing the correct grade they were advertising, than a sensor reading issue.
So i still think something is not right on this particular setup. If the installer had wired it to +5V rather than +12V would it read anything at all?
				Posted: Thu Apr 11, 2019 11:42 pm
				So it's a new install, never run before ?
rather than something where you are seeing discrepancies ?
I'm sure you've seen this video that shows how water can massively skew readings should there be any moisture in the system
https://www.youtube.com/watch?v=8DZhLjwsWVY
				Posted: Fri Apr 12, 2019 1:21 am
				by johnfelstead
				It's been on the car for ages but never used actively. I'm looking at the car and map for the first time and noting it's not reading correctly, so i need to work out what's going on before using it to reference when using a meth mix flex fuel setup.
The car has never used Methanol or Ethanol, it's just been run on Shell V-Power, so there should be no issues with water contamination etc.
				Posted: Fri Apr 12, 2019 10:04 am
				Dumb question, but is the sensor setup right, with the correct 0% and 100% frequencies (usually 50Hz-150Hz, but don't know which sensor you're using)?
				Posted: Fri Apr 12, 2019 10:31 am
				by johnfelstead
				Hi Tim,
yes all the Cal file settings for the sensor are correct.
I havent checked the wiring yet, as i dont have the car with me, but would it read if only fed with 5V?
Sensor was supplied by Scoobyclinic about 4 years ago.
				Posted: Fri Apr 12, 2019 4:26 pm
				johnfelstead wrote: Fri Apr 12, 2019 10:31 am
Hi Tim,
Sorry for not replying sooner - not been getting any email notifications from this forum since they updated it!
I have just tried a sensor on the bench and it works down to around 4.5V, and the frequency of the output remains the same at all supply voltages.
