Fuel pump PWM strategy
Posted: Sun Nov 04, 2018 5:34 pm
I wanted to design a fuel system up so that I could PWM the primary pump to hold a relative fuel pressure of 3000mbar, hoping to reduce the fuel temperature and also to assist with holding the fuel pressure steady to help with mapping accuracy on fuel control.
Once the system is fully functioning, the hope is that when pump 2 and pump 3 kick in, the PWM strategy will keep the fuel pressure steady at 3000mbar.
The following refers to a S6 plus plug and play ECU in my R35 GTR
There is a fore innovations triple pump set-up in my car with 3 TI Auto F90000274 pumps that are suitable for E85 and PWM.
To get the system running I used one solid state relay and two traditional relays triggered at higher load.
If the system is not flexible enough to switch in the traditional relays and hold fuel pressure, there would be the simpler option of PWM all three pumps together rather than switching pumps in.
Here is how I wired the Solid state relay – please note the Fly-Back diode to safely manage the current generated when the pump is PWM'd off.
I ended up using a 1N5408 diode rather than the 1N4007 on the schematic for added safety.
Here is the solid state relay I used https://www.schneider-electric.com/en/p ... SP1D440BDT
Picture of the SSR installed - I later changed the power on wire (bottom left) to be an ignition on switched wire rather than permanently powering the SSR.
Initially I struggled to get the pump to run with PWM using the PWM3 / FUEL11 pin which has a pullup resistor.
I switched to PWM6 / Fuel 14 which has no pullup and initially the circuit still it did not work, so went back through the settings to ensure there was not something set wrong.
Bingo, here are the settings I used that got the PWM working.
PWM pump control enable – Enabled
Output Drive Type – LOW-SIDE
PWM frequency – 100Hz
Off Duty – 0%
Priming Duty – 35%
Run on Duty – 40%
Pump PWM Y Axis breakpoints - 200 850 1500 2150 2800 3000 3200 3400 3600 3800 4000
Base Duty all points set to 33%
Referring to Ryan’s help video.
https://www.youtube.com/watch?v=IVIdYESOuOQ
I created a new table with Relative fuel pressure on the X axis and PWM duty multiplier on the Y axis.
Closed Loop Fuel Pump Pressure Enable – Enabled
Fuel Pump Pressure target table values set at 2000mbar above MAP pressure.
Fuel Pump Pressure Error Breakpoints -1000 to 1000
Fuel Pump Pressure Proportional Duty Adder – not in use
Fuel Pump Pressure Integral Duty Adder – not in use
Fuel Pump Pressure Integral Duty Adder Minimum – -50%
Fuel Pump Pressure Integral Duty Adder Maximum – 50%
Fuel Duty Minimum – 0%
Fuel Duty Maximum – 100%
The car starts and runs, I did try and make the system work with the following controls without luck - please let me know if you made your PWM with the following controls.
When I used them the numbers I used made the PWM climb rather than seek 3000mbar, so may just be a poor choice of numbers.
I have still to drive the car hard to see what happens with the fuel pressure.
Any thoughts?
Hugh
Off Duty – 0%
Priming Duty – 35%
Run on Duty – 40%
Any thoughts?
Hugh
