Page 9 of 9
Re: Launch Control Settings
Posted: Mon Apr 18, 2022 2:14 pm
by johnfelstead
Is it even possible to use an analogue sensor for triggering a clutch position function on an S6? The inputs available seem to only allow a switch.
Posted: Mon Apr 18, 2022 2:18 pm
I have a pressure sensor on my own car, and things are not so simple.
It is actually quite a huge variable not just on pedal position, but also how fast/slow the pedal is being moved in either direction.
A linear pot would be a lot more consistent, but not something I bothered to try yet. Using pressure for things that need fine control...nope, just too difficult IMO.
But as the "clutch switch" can be defined based on clutch pressure/position....I would assume it could be used ok with a linear pot ? and is a variable you could play with.
More recently I have added a "wheel" speed sensor onto my propshaft ( well it was there as the regular VSS on my T56 but I never used it before...VR...but seems to pick up fast, might switch to Hall later if it doesn't do what I hope ) as this should pick up "speed...ie movement in the drivetrain to switch to main launch" faster than actual wheel speeds.
Plus annoyingly since I moved my rear wheel speeds to the X10....they just do not seem as reliable as they were with direct to the S8. Hmmmm, methinks the X10 has a few niggles.
The VSS Prop speed trigger is direct to S8.
Posted: Mon Apr 18, 2022 2:21 pm
And you seem correct...I do not see clutch position or pressure in the S6.
Posted: Mon Apr 18, 2022 2:28 pm
by johnfelstead
stevieturbo wrote: Mon Apr 18, 2022 2:18 pm
How would you do that? I cant see it as an option in the S6 software? Or are you suggesting to use the high and low trigger voltages and not a proper pressure sensor linearisation?
Posted: Mon Apr 18, 2022 2:29 pm
by johnfelstead
stevieturbo wrote: Mon Apr 18, 2022 2:21 pm
beat me to it.
Posted: Mon Apr 18, 2022 2:37 pm
buy an S7 or S8 lol
Posted: Mon Apr 18, 2022 2:38 pm
by johnfelstead
stevieturbo wrote: Mon Apr 18, 2022 2:37 pm
buy an S7 or S8 lol
