Page 2 of 2
Re: honda 3 wire denzo coils
Posted: Tue Aug 20, 2013 12:59 pm
by ford racing
forgot to say second bank r mike moran injectors
Posted: Sun Aug 25, 2013 6:15 pm
by ford racing
hi pavlo just to clarify coil wiring, do you mean +12 and signal together and ground to ecu or +12 and ground to coil and signal to ecu .and where does resistor need to go
Posted: Mon Aug 26, 2013 2:23 am
by pavlo
Like I said it depends on how you want to do it.
ONLY FOR COILS WITH BUILT IN AMPLIFIERS:
To run them as normal TTL (so thats +5v signals that got high for the dwell time then back to ground) connect the +12v on the coil to ignition switched +12v, ground to engine ground (however you choose) signal on coil to ignition output from ECU. I used a 200ohm resistor between the ignition output and ground but many coils don't need anything. Set the Ignition output type as TTL and TTL voltage to 5v.
Posted: Mon Aug 26, 2013 11:36 am
by ford racing
thanks for help ,steve
