Latest Firmware Releases
Technical Help / Firmwares for the VAG MQB Range - Audi RS3 / TTRS
Re: Latest Firmware Releases
Changes since 1.25.1:
* Added LatG Duty Adjustment
OLD BOARD - Firmware Version 1.27.1 - http://www.syvecs.com/downloads/AWD_AudiMQB_1-27-1.enc
NEW BOARD - Firmware Version 1.27.1 - http://www.syvecs.com/downloads/X4AWD_A ... 1-27-1.enc
1.29 Firmware Release
Changes since 1.27.1:
* USB Data-Logging
* Programming Fix
OLD BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/AWD_AudiMQB_1-29-1.enc
NEW BOARD - Firmware Version 1.29.1 - https://www.syvecs.com/downloads/X4AWD_ ... 1-29-1.enc
Locked
Return to “VAG MQB5 Range - Audi RS3 / TTRS”
