Learn Maps - committing to base maps?
beetos
Post by beetos »
Hi
Does anyone know if the 'learn' maps (For idle base duty, knock/cylinder trim, WG duty etc) can be committed to their respective base map or do they just exist as separate constantly changing maps? Other ECU's I have used allow you to commit to the base map and zero out the learn map, wondered if you can do this on the syvecs.
Slowie
Re: Learn Maps - committing to base maps?
Post by Slowie »
Hi
When you are viewing the actual learning correction map (e.g. Base Wastegate Control Duty Learning / Learned Correction 1) you can use the Learn menu (top right) to apply or reset the learned correction to the base map.
beetos
Post by beetos »
Thank you! I missed that feature.
klakling
Post by klakling »
You can use the Learn menu (top right) to apply or reset the learned correction to the base map.
After covit, my need to travel is also growing. I mostly use the map to locate the best direction for myself classic games Spades
superedan
Post by superedan »
beetos wrote: Sun Nov 13, 2022 11:26 am Hi
Does anyone know if the 'learn' maps (For idle base duty, knock/cylinder trim, WG duty etc) can be committed to their respective base map or do they just exist as separate constantly changing maps? Other ECU's I have used allow you to commit to the base map and zero out the learn map, wondered if you can do this on the syvecs. Melon Playground Game
Syvecs treats learning as an adaptive system rather than a calibration shortcut. The learned data is there to enhance performance on the fly, not to replace the need for proper base tuning.
