Latest Base Maps
Latest Base Maps
For use with 1.21 Firmware
- AwdBase_YarisGR 1.21.SC
- (46.26 KiB) Downloaded 3128 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_YarisGR 1.23.SC
- (51.46 KiB) Downloaded 2946 times
- AwdBase_YarisGR 1.23 X4.SC
- (51.46 KiB) Downloaded 3022 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_YarisGR 1.24.SC
- (55.83 KiB) Downloaded 2910 times
- AwdBase_YarisGR 1.24 X4.SC
- (55.78 KiB) Downloaded 3161 times
1.25
- AwdBase_YarisGR 1.25 X4.SC
- (61.05 KiB) Downloaded 3350 times
Re: Latest Base Maps
For use with 1.27 Firmwares
- AwdBase_YarisGR 1.27.SC
- (66.84 KiB) Downloaded 1387 times
- AwdBase_YarisGR 1.27 X4.SC
- (66.87 KiB) Downloaded 1393 times
- AwdBase_YarisGR 1.28 X4.SC
- (72.44 KiB) Downloaded 821 times
1.29 Base map
- AwdBase_YarisGR 1.29 X4.SC
- (72.89 KiB) Downloaded 895 times
1.34 Base map
Base maps for Gen1 and Gen2 Yaris AWD 1.34 firmware
- AwdBase_YarisGR 1.34 X4.SC
- (31.31 KiB) Downloaded 50 times
- AwdBase_Yaris24 1.34 X4.SC
- (31.31 KiB) Downloaded 59 times
