The latest Infiniti AWD Base map which matches the latest firmware can be found below in Attachments
Latest Base Map
Latest Base Map
- AwdBase_QX60 1.15.SC
- (38.8 KiB) Downloaded 3247 times
1.18
- AwdBase_QX60 1.18.SC
- (42.89 KiB) Downloaded 3540 times
1.21 Base Map
For use with 1.21 Firmware
- AwdBase_QX60 1.21.SC
- (46.26 KiB) Downloaded 3534 times
1.23 Base Maps
For use with 1.23 Firmwares
- AwdBase_QX60 1.23 X4.SC
- (51.46 KiB) Downloaded 3304 times
- AwdBase_QX60 1.23.SC
- (51.46 KiB) Downloaded 3060 times
1.24 Base Maps
For use with 1.24 Firmwares
- AwdBase_QX60 1.24 X4.SC
- (55.78 KiB) Downloaded 3434 times
- AwdBase_QX60 1.24.SC
- (55.83 KiB) Downloaded 3050 times
1.25
- AwdBase_QX60 1.25 X4.SC
- (61.05 KiB) Downloaded 3122 times
Re: Latest Base Map
For use with 1.27 Firmwares
- AwdBase_QX60 1.27 X4.SC
- (66.87 KiB) Downloaded 1228 times
- AwdBase_QX60 1.27.SC
- (66.84 KiB) Downloaded 1133 times
Re: Latest Base Map
For use with 1.28 Firmware
- AwdBase_QX60 1.28 X4.SC
- (72.44 KiB) Downloaded 959 times
Re: Latest Base Map
1.29 base map
- AwdBase_QX60 1.29 X4.SC
- (72.89 KiB) Downloaded 889 times
