Latest S12 Firmware
Ryan.g
Syvecs Staff - Caretaker
Re: Latest S12 Firmware
Post by Ryan.g »
This Link - CLICK HERE is for version 1.693 of the S12 firmware.
Changes Since 1.678
(in 677)
(in 678)
(in 680)
* new cm map use: n2oDutyMlt
(in 682)
(in 687)
* new cm map - DBW Multiplier
* rs232 25hz transmit option
(in 688)
(in 690)
(in 693)
Ryan.g
Post by Ryan.g »
This Link - CLICK HERE is for version 1.699 of the S12 firmware.
Changes Since 1.693
(in 694)
(in 696)
(in 699)
Ryan.g
Post by Ryan.g »
This Link - CLICK HERE is for version 1.711 of the S12 firmware. RIGHT CLICK AND COPY LINK IF DOESN'T AUTOMATICALLY DOWNLOAD
Changes Since 1.699
702
705
706
708
We then have
709
710
711
