DBW PPS too slow to respond
Gpro
Post by Gpro »
Hi,
I have an issue where my pedal position sensor takes too long to react from 100% to 0% when lifting off. This causes my car to over-rev when shifting gears due to throttle body not closing fast enough thereby delaying 'TPSClosed' state for overrun to kick in.
I must stress the issue here isn't the TPS but the PPS. I have attached a log, take a look at the last 6 ppsA and ppsB spikes. It takes 120+ miliseconds to go from 100% to zero which is too long. On a stock mechanical setup it was 40ms.
The car is a Supra mk4 running DBW on a Syvecs S7 Plus.
Any help or guidance would be much appreciated.
2022-02-10 10-20-11 plus 0h00m00s S7#15020.SD
(456.31 KiB) Downloaded 1024 times
amdisthebest
Re: DBW PPS too slow to respond
Post by amdisthebest »
Can you also log the AN0X channels the PPSA/B are attached to and/or ppsAV/ppsBV?
What is the pedal from?
