Hey guys,
we just try to fit the S7+ Plug & Play kit in our 997.2 Turbo.
We realized, that we need to replace the EGT sensors to K-type with the K8 expander, and now we got the next problem.
We are using MPI injectors and are wondering, where we need to pin them, as all connectors are occupied already.
Is there anybody who installed the kit already and can advise, if there are any pinouts, we can use for the 6 additional injectors?
						S7+ Pinout for secondary fuel injectors 997.2 TT
Moderator: Wez
Re: S7+ Pinout for secondary fuel injectors 997.2 TT
How many injectors does it run from the factory ?
Wiring info here ?
http://www.syvecs.com/downloads/Syvecs_ ... NP_Kit.pdf
						Wiring info here ?
It might get more attention on the FB page....the forum just doesn't seem to get much attention.
But presumably if the other functions are already in use...you're kinda screwed for using them as injectors ? Unless the other untimed functions can be moved to an expander or something to allow the ecu board to be used as injectors.
That is exactly the problem
Why purchasing a Plug & Play System with all that functions, if they are nnot available together?
I will try the FB group, thx
A plug n play kit is as the name implies, to work in a standard car, it plugs in, no or minimal wiring involved and working with all the cars functions.
I presume it does this already ?
If you want to add further accessories or control items you may need upgrades, or wiring alterations etc.
Understood, i already found a solution with Ryan, good support so far anyway
				Prestigeperformance
Glad to hear you came up with a solution! May i ask what it was? We are currently tuning a 991 the we want to put on E85 and will require extra fueling.
John
John
We have our own fueling adaptors
https://www.tij-power.com/product_info. ... anguage=en
Syvecs can handle FSi + MPi injectors only together
