Hi,
I am trying to set (Load) a new Scfg calibration onto my ECU.
The file I am using is from my tuner, and is Scfg Software Version 1.518.1.
When trying to Set the file onto my ECU using Scfg, I get and error that requests I convert the file to 1.538
I am using, and only have ever loaded, the latest software and firmware. I have no older versions on my PC.
When trying to convert the file in Scfg from 1.518.1 to 1.538, I obviously don't have anything in the directory the pops us that is obvious to use to convert the file.
Can someone help with this process pls.
Thanks.
Scfg 1.518.1 file to 1.538
Re: Scfg 1.518.1 file to 1.538
I think it is prob similar to updating a cal, in sCfg there is an option to change software version.
Open your file, change version in sCfg, save the new version and try that?
Thanks for the reply Wez, it did help me figure out the problem.
I did not have the firmware update file correctly located in my workspace, so could not find it when using the Config / change software version facility in SCfg.
All sorted and working now. Thanks again.
