Syvecs Android App Chat - BETA Now Available!!!
Moderator: Wez
Wez
Santa's Little Helper
Re: Syvecs Android App Chat - BETA Now Available!!!
Post by Wez »
Tidgy wrote:Might be me being dum, but I can't find oil pressure, temp and boost info in the gauge options on it.
Hiya, boost is on there but listed as Manifold Pressure, I will add a new item called Boost, also just noticed that Oil temp and pressure are missing, I will get those added and upload a new version.
I will get a few more added took, any others that people want?
Tidgy
Post by Tidgy »
Cheers chap, found the manifold pressure in the end when i went hunting.
Suggestion for future, how about a setable warning level, changes the background of the gauge to red or something like that when the reading goes over a certain target?
Wez
Post by Wez »
Tidgy wrote:Cheers chap, found the manifold pressure in the end when i went hunting.
OK great :)
Already on the list, along with high / low peak review etc :D
Always looking for suggestions and ideas, post here detailing which app version you are talking about ;)
viewtopic.php?f=26&t=740
Tidgy
Post by Tidgy »
Other thing i noticed on my phone im only see a speedo type gauge, when i go in and change it to the levelmeter one nothing changes.
Im not linked into the car yet so only in test mode and playing with settings so don;t know if that makes any difference?
Wez
Post by Wez »
Tidgy wrote:Other thing i noticed on my phone im only see a speedo type gauge, when i go in and change it to the levelmeter one nothing changes.
That a new one on me, should work fine in demo mode.
What device and version of Android are you using?
Tidgy
Post by Tidgy »
Samsung S6, should be what ever the latest version is at a guess. Phone lists Android version 5.1.1
I'm up at clinic tomorrow so can have a chat with pat if he's up and see if its me hahaha
Tidgy
Post by Tidgy »
Hi Wes, any news on updated software version?
Cheers T
Wez
Post by Wez »
Tidgy wrote:Hi Wes, any news on updated software version?
Cheers T
Hiya,
BETA release 2 was posted on Jan 29th, is this the one you are referring too?
Tidgy
Post by Tidgy »
Not sure, did oil temp get added?
Also been having issues connecting it to my car. says its receiving (green light is flashing, is that right? and getting packet transfers) but the revs fluctate between 0 and 400 rpm (no mater what revs the cars actualy doing) and doesn't look to be getting any other signals or they are maxed all the time.
Its supposedly paired but am i missing something i should be doing to connect it?
Cheers T
Wez
Post by Wez »
Oil P and T should be included in that build, I will double check.
If you are getting a green blinking light and packet count that shows the bluetooth is connected and is receiving valid CRC checked packets.
Have you matched up the app datastream allocation with the output from the custom CAN on the ECU? The frame and slot needs to match to ensure that correct calculations etc are applied to the data frames.
