Apologies if this has already been covered (I couldn't find anything)- what is the preferred crimping tool(s) for the S8 connector pins? Is something specific needed or will something like the Paladin 2033 or a Metripack crimper work well?
Preferred Crimper?
Re: Preferred Crimper?
I would try those two tools and see what the crimps are like. I use a Durite tool intended for junior and microtimer terminals and that does a great job for around £50.
I've used a cheap WeatherPack/MetriPak crimper (like the one DelCity sells) to do a few connectors quite successfully.
Now that you posted it I might buy the Paladin die just to try it out.
Is it one of the following?TimH wrote:I would try those two tools and see what the crimps are like. I use a Durite tool intended for junior and microtimer terminals and that does a great job for around £50.
http://www.gsparkplug.com/durite-ratche ... 03-52.html
http://www.gsparkplug.com/durite-ratche ... 03-53.html
The second of those (for JT terminals rather than JPT).
Thanks TimTimH wrote:The second of those (for JT terminals rather than JPT).
