Latest S8C Firmware
Ryan.g
Syvecs Staff - Caretaker
Re: Latest S8C Firmware
Post by Ryan.g »
PLEASE USE 1.693 as has significant improvements
Changes Since 1.687
(in 688)
(in 690)
Ryan.g
Post by Ryan.g »
This Link - CLICK HERE is for version 1.693 of the S8 firmware.
Changes Since 1.678
(in 677)
(in 678)
(in 680)
* new cm map use: n2oDutyMlt
(in 682)
(in 687)
* new cm map - DBW Multiplier
* rs232 25hz transmit option
(in 688)
(in 690)
(in 693)
Ryan.g
Post by Ryan.g »
This Link - CLICK HERE is for version 1.699 of the S8 firmware.
Changes Since 1.693
(in 694)
(in 696)
(in 699)
Ryan.g
Post by Ryan.g »
This Link - CLICK HERE is for version 1.711 of the S8 firmware. RIGHT CLICK AND COPY LINK IF DOESN'T AUTOMATICALLY DOWNLOAD
Changes Since 1.699
702
705
706
708
We then have
709
710
711
Locked
