2008 Subaru does not start
Posted: Sat Jun 24, 2017 10:42 pm
Dear All:
I am running the S6GP PnP kit for the 2008 Subaru WRX/STI Hatchback.
When you turn the car on, the ECT gauge is high. When you try to start nothing.
Any idea what the issue can be?
FUEL 01, Cylinder 01 Primary Injector
FUEL 02, Cylinder 02 Primary Injector
FUEL 03, Cylinder 03 Primary Injector
FUEL 04, Cylinder 04 Primary Injector
FUEL 09, Tacho
FUEL 10, Starter Enable
FUEL 11, Wastegate 1 Control
FUEL 12, Air Con Control
IGN 01, Cylinder 01 Primary Ignition
IGN 02, Cylinder 02 Primary Ignition
IGN 03, Cylinder 03 Primary Ignition
IGN 04, Cylinder 04 Primary Ignition
IGN 05, Fuel Pump 1
IGN 06, Drive By Wire 1
LAMBDA V, Lambda Sensor 1
AB01 AN 01 (5V/BI), Crank Position Sensor A
AB02 AN 02 (5V/BI), Manifold Absolute Pressure Sensor 1A
AB03 AN 03 (5V/BI),
AB04 AN 04 (5V/BI),
AU01 AN 05 (5V/TH), Cam (Phase) Sensor / Cam (Inlet 1 Variable Valve Timing) Sensor
AU02 AN 06 (5V/TH), Cam (Inlet 2 Variable Valve Timing) Sensor
AU03 AN 07 (5V/TH), Cam (Exhaust 1 Variable Valve Timing) Sensor
AU04 AN 08 (5V/TH), Cam (Exhaust 2 Variable Valve Timing) Sensor
AV01 AN 09 (5V), Throttle Position Sensor 1A
AV02 AN 10 (5V), Throttle Position Sensor 1B
KT+,
AV03 AN 11 (5V), Pedal Position Sensor A
AV04 AN 12 (5V), Pedal Position Sensor B
AR01 AN 13 (TH), Engine Coolant Temperature Sensor 1
KNOCK, Cylinder 01 Knock / Cylinder 02 Knock / Cylinder 03 Knock / Cylinder 04 Knock
AR02 AN 14 (TH), Air Charge Temperature Sensor 1
AR03 AN 15 (TH), Air Con Switch
AR04 AN 16 (TH),
FUEL 13, Lambda Heater 1
FUEL 14, Sensor Warning Light
FUEL 15, Fan 1
FUEL 16, Fan 2
FUEL 05, Variable Valve Timing 1 Inlet A
FUEL 06, Variable Valve Timing 2 Inlet A
FUEL 07, Variable Valve Timing 1 Exhaust A
FUEL 08, Variable Valve Timing 2 Exhaust A
RUN STRATEGY WITHOUT PIN,
SLAVE1 AN #01,
SLAVE1 AN #02,
SLAVE1 AN #03,
SLAVE1 AN #04,
SLAVE1 AN #05,
SLAVE1 AN #06,
SLAVE1 AN #07,
SLAVE1 AN #08,
SLAVE1 AN #09,
SLAVE1 AN #10,
SLAVE1 AN #11,
SLAVE1 AN #12,
SLAVE1 AN #13,
SLAVE1 AN #14,
SLAVE1 AN #15,
SLAVE1 AN #16,
SLAVE1 AN #17,
SLAVE1 AN #18,
SLAVE1 AN #19,
SLAVE1 AN #20,
SLAVE1 AN #21,
SLAVE1 AN #22,
SLAVE1 AN #23,
SLAVE1 AN #24,
SLAVE1 AN #25,
SLAVE1 AN #26,
SLAVE1 AN #27,
SLAVE1 AN #28,
SLAVE1 OUT #01,
SLAVE1 OUT #02,
SLAVE1 OUT #03,
SLAVE1 OUT #04,
SLAVE1 OUT #05,
SLAVE1 OUT #06,
SLAVE1 OUT #07,
SLAVE1 OUT #08,
SLAVE1 OUT #09,
SLAVE1 OUT #10,
SLAVE1 OUT #11,
SLAVE1 OUT #12,
SLAVE1 OUT #13,
SLAVE1 OUT #14,
SLAVE1 OUT #15,
SLAVE1 OUT #16,
SLAVE1 OUT #17,
SLAVE1 OUT #18,
SLAVE1 OUT #19,
SLAVE1 OUT #20,
SLAVE1 OUT #21,
SLAVE1 OUT #22,
SLAVE1 OUT #23,
SLAVE1 OUT #24,
SLAVE1 OUT #25,
SLAVE1 OUT #26,
SLAVE1 OUT #27,
SLAVE1 OUT #28,
FUEL 09, Tacho
IGN 05, Fuel Pump 1
AB03 AN 03 (5V/BI),
AB04 AN 04 (5V/BI),
KT+,
AR04 AN 16 (TH),
FUEL 15, Fan 1
FUEL 16, Fan 2
SLAVE1 AN #01,
SLAVE1 AN #02,
SLAVE1 AN #03,
SLAVE1 AN #04,
SLAVE1 AN #05,
SLAVE1 AN #06,
SLAVE1 AN #07,
SLAVE1 AN #08,
SLAVE1 AN #09,
SLAVE1 AN #10,
SLAVE1 AN #11,
SLAVE1 AN #12,
SLAVE1 AN #13,
SLAVE1 AN #14,
SLAVE1 AN #15,
SLAVE1 AN #16,
SLAVE1 AN #17,
SLAVE1 AN #18,
SLAVE1 AN #19,
SLAVE1 AN #20,
SLAVE1 AN #21,
SLAVE1 AN #22,
SLAVE1 AN #23,
SLAVE1 AN #24,
SLAVE1 AN #25,
SLAVE1 AN #26,
SLAVE1 AN #27,
SLAVE1 AN #28,
SLAVE1 OUT #01,
SLAVE1 OUT #02,
SLAVE1 OUT #03,
SLAVE1 OUT #04,
SLAVE1 OUT #05,
SLAVE1 OUT #06,
SLAVE1 OUT #07,
SLAVE1 OUT #08,
SLAVE1 OUT #09,
SLAVE1 OUT #10,
SLAVE1 OUT #11,
SLAVE1 OUT #12,
SLAVE1 OUT #13,
SLAVE1 OUT #14,
SLAVE1 OUT #15,
SLAVE1 OUT #16,
SLAVE1 OUT #17,
SLAVE1 OUT #18,
SLAVE1 OUT #19,
SLAVE1 OUT #20,
SLAVE1 OUT #21,
SLAVE1 OUT #22,
SLAVE1 OUT #23,
SLAVE1 OUT #24,
SLAVE1 OUT #25,
SLAVE1 OUT #26,
SLAVE1 OUT #27,
SLAVE1 OUT #28,
