Question on C4 ground
Posted: Tue Nov 01, 2016 1:19 pm
Hi - Just been familiarizing myself with the S6Plus Pinouts and Wiring pdf.
There *seems* to be a contradictory statement relating to pin C4:
...Under the "Connecting Power" section we have C4 listed as a Power Ground with the note:
"NOTE! Power Grounds are designed to conduct High Current loads – Do not mix Power Grounds with Analogue (AN) Grounds."
...Under the "Sensor/ Analogue Grounds (AN Grounds)" section we again have C4 listed with the note:
"these grounds must be kept separate from the Power grounds shown in the first section"
...Am I missing something of is this an error in the document? I **think** C4 is a true AN Ground as that how my adapter loom from Pat @ Syvecs is wired.
