				Anti Lag System fuel multiplier request
				Posted: Mon Jun 29, 2015 7:47 pm
				by KulinPapa
				Would it be possible if ALS fuel multiplier could be set between 0.0 and 2.0. (Not only between 0.0 and 1.0)  On this way it could be possible to add some fuel in antilag mode if needs. Thanks.
				Re: Anti Lag System fuel multiplier request
				Posted: Tue Jun 30, 2015 11:05 am
				by pavlo
				You don't need more fuel for effective ALS, bearing in mind the anti lag system is there to reduce lag, not to spit flames!
If you want to reduce EGT you need to add fuel cut, as this brings in fresh air which has a big effect and you can easily reduce the EGT even with large amounts of bypass.
If you want to spit big flames then yes perhaps a fuel multiplier would be nice but it will not be nice for the engine to dump lots of fuel.
What problems are you having with it at the moment?
				Posted: Tue Jul 07, 2015 3:02 pm
				by KulinPapa
				I agree with you. I dont have problems with antilag now. But some of my customers would like to see more flames behind the car. And i thought, it could add more flexibility to the software.
