Barometric pressure?
Posted: Tue May 13, 2014 9:17 pm
Hi All,
Was after a bit of guidance on barometric pressure effect on idle on my 02 STI 2.35.
Car idles around 0.95 lambda during fine weather but idles very lean around 1.07 to 1.09 during wet/stormy weather, which means it often stalls at junctions etc. This has been happening for about a year now so I'm wondering if I have a sensor failure.
The BAP reading is always sat at 955mbar on SCal and BAPv gives no reading at all. Should this be working and therefore making barometric fuel corrections or am I barking up the wrong tree?
I don't run wideband at idle btw, only once on the move so car runs target lambda perfectly. Just idles very lean in foul weather.
Any advice much appreciated.
cheers
Justin
cheers
Justin
