NTK L2H2 vs. LC-1 w/ LSU 7200 differences
Posted: Sat May 07, 2011 4:54 pm
Dear Syvecs Users/Pat,
I have received NTK sensors from Charlie and have connected one directly to the Syvecs S6GP that I run. After getting it up and running I did some runs with NTK sensor mounted in the Bellmouth of the downpipe and the LC-1 w/ LSU 7200 sensor (that I used to map the car) in the Rear O2 sensor position on the downpipe. The readings between the 2 differ way too much for my liking. I have included a LOG file and would be happy for all suggestions/comments.
Calculating AFRs based on Injector size and IDCs also makes the AFR I get from the LC-1 much more likely. I could ofcourse alter the NTK calibration but assuming this is the calibration that should basically work I think maybe something else is wrong.
Car specs:
2006 WRX w/ OE engine
TD06-20G 8cm2 @ 1.3 Bar boost
ID1000 injectors @ 3.5Bar static pressure
Jasper.
Car specs:
Jasper.
