Ah, proper instructions, I do so dream of those.
The ECU wont start the car, making it (behind the car itself) my second most expensive paperweight.
There are threads on the Motec & EFI101 sites, but in summary:
Motec MLS ECU with all options (it is a cutdown M4 for just LSx and Lexus V8s).
GM LS1 (5.7l V8) with factory sensor.
New engine loom with the minimum number of sensors, cam&crank sensor wires are shielded.
Factory coils & I've refitted the factory injectors.
Engine itself has heads, cam, etc. but should start & run (albeit very leanly) on a standard factory map.
Was running on the factory ECU prior to fitting the Motec.
Regretably I hacked the factory loom to put together a prototype loom for the Motec, so can't go back.
Factory 58psi fuel pressure.
No startup map supplied, so using an LS2 map with what I believe are the necessary changes for cam&crank sensor setup.
I don't have a decent enough scope to give an accurate output of the cam & crank sensors, but below is what I get with the cheap nasty scope - at least shows that both sensors are working and that it has the normal 24 tooth trigger wheel.
No TDC mark on engine to check timing. Hopefully a piston stop will get delivered next week and I can rectify this lack of information.
Out of probably upwards of a thousand attempts to start the car (I eventually bought a massive battery for just this purpose) it has started twice. Once last year on the prototype loom, ran for a few seconds until I shut it off as the exhaust header had blown apart the last time I was out in the car and I'd forgotten about it making the car a tad loud and rough. Wouldn't restart. A few weeks back it started, ran for about 30 seconds sounding happy, then died and wouldn't restart - a splutter, splutter death, so I just figured the fueling was miles out, but nope.
Ignition and injector test are fine. If you run the ignition test after an injector test it is sometimes possible to get it to ignite the fuel and turn the engine enough that the ECU s/w says to not run diagnostics on a running engine.
All sensors return expected values. Cranking rpm is reported in the s/w as being around 110 using the big battery, 130-150 with the tiny battery (but you only get one chance with it before having to dig out the charger).
Motec support referred me back to the ECU supplier, but I am having trouble getting them to come up and look at the car. Have e-mailed Motec asking if they can run a test on the ECU if I send it to them - just in case there is a fault with it.
Wiring & Setup Word Document
