5V outputs on S6PnP
Posted: Fri Feb 04, 2011 8:14 pm
by RichardB
Hi guys,
I was trying to add a second map sensor to monitor EGBP. When wired into the 5V output on B09 I was getting TPS sensor voltage errors and the car wouldn't start. As soon as the sensor is disconnected from B09, all goes back to normal. The ground was wired to the main ecu ground. Could it be that this is just one sensor to many for this 5V output? I thought there was a second 5V output, but can't seem to find it listed on the S6Pnp pinout. Can anyone point me in the right direction please?
Richard
Re: 5V outputs on S6PnP
Posted: Sat Feb 05, 2011 12:07 pm
by Charlie
Have you tried pin 9 on the aux connector on the rear of the board ?
Posted: Sat Feb 05, 2011 6:38 pm
by RichardB
Nope. Thanks Charlie, I'll give that a try.
Posted: Sun Feb 06, 2011 3:20 pm
by RichardB
Thanks Charlie, all sorted. :D
My oe ecu casing had only been cut away around the LAN port, so the AUX connector was not initially visible.
