Latest Firmware Releases
Posted: Fri Nov 08, 2024 6:26 am
by Ryan.g
Version 1.107 is the first release of the OEX Firmware
Help on updating the firmware can found via - https://www.syvecs.com/downloads/Syvecs_Updater.pdf
Firmware Version 1.107 - www.syvecs.com/downloads/X20OEX_1.107.1.enc
Re: Latest Firmware Releases
Posted: Fri Jun 20, 2025 6:33 am
by Ryan.g
Version 1.114 Adds the following updates:
// 1.108 - Added Bmw and Supra CAN, Added Enable for 29bit in GenericRX
// 1.109 - Added Enable RPM and Tps for External WG, Fixed RPM in Focus RS Mk2, Fixed Wheel Speeds in BMW2020
// 1.109.2 - Sensor filtering tweak
// 1.110 - Added OBD2 TX Options, Coolant Pressure limp and maps
// 1.110.2 - Output Test fix, 20, 40, 60, 80% issue
// 1.111 - Added Generic TX CAN Frames
// 1.111 - TinyDash CAN Option
// 1.112 - Change User Rename items to be more flexible
// 1.113 - WG Turbo Speed sensors added and R35GTR Custom CAN Transmit waits for RPM
// 1.114 - Turbo Speed Control in WG Strategies
// 1.114.2 - Add option for SyncState to be set from GenRX or ICan sensors if no Crank Pin is assigned, so strategies like fuel pump work
Firmware Version 1.114 - www.syvecs.com/downloads/X20OEX_1.114.2.enc
Posted: Thu Aug 14, 2025 2:57 pm
by Ryan.g
Version 1.115 Adds the following updates:
// 1.114.3 - Sensor Filtering wrong for LAM1 and LAM2 as different REP
// 1.115 - Updated Help for Crank and Cam and Fixed so AN8 + can be used for Crank and Cam
// 1.15.2 - Programming Code adjustment
Firmware Version 1.115 - www.syvecs.com/downloads/X20OEX_1.115.2.enc
