4G63 Crank/Cam trigger?
Posted: Fri Nov 27, 2009 9:17 pm
Hi,
I'm in the process of putting a 4G somewhere it shouldn't be, and am wondering what's the best way to deal with the crank trigger?
I see the new S6 firmware has capability for the OE 4G crank and cam sensor, but is my S6 capable of handling this trigger? I recall reading that only the later FPGAs will handle this?
Before the new code was released my plan was to use a 36-1 trigger wheel for the crank, and possibly use the cam sensor too.
Now there's the possibility that the OE setup might work, only it seems the resolution is quite poor.
What should I do, and what are the pros/cons of each?
OE setup (assuming my S6 can cope with it) - low resolution?
Crank trigger disc and OE cam sensor - best scenario?
Crank trigger disc only - wouldn't sense cam belt breakage, but would it actually make much difference to resulting damage over disc alone?
Thanks,
Jezz.
Thanks,
Jezz.
