Auto blip doesn't work properly GR Yaris
For Toyota Technical Chat.
StephenB
Post by StephenB »
Hi colleagues
I have some strange behaviour with 'MIT' enabled.
When i engage the clutch and hold on the car starts to 'auto blip' repeately , even when no gears are shifted or up-shifting, eventually followed by a 'REV limit'... :/
Would someone be so kind to explane me a bit more into detail how the ECU knows the difference between 'gear cut' & gear blip'? I assume there are some parameters not set-up correctly.
I received some feedback that this was not the case with the previous 'basic OEM' file?
Thanks in advance.
Kind regards,
