First Syvecs ECU so noob warning!
I was looking in SCal and the solution didn't jump out at me based on the options available so I figured I would ask the group here.
So I have 2 cal switches (TC and Map) wired to an ECUMaster CanBoard in my steering wheel that sends the selector values on CAN2 as follows:
Map:
ID=0x642 - offset=2 - 8bit where each position on the switch is a distinct hex value
TC:
ID=0x642 - offset=3 - 8bit where each position on the switch is a distinct hex value
How would you go about mapping those distinct hex values to their desired strategies or can it only be done by voltage input?
I guess I am just wanting to make sure selecting Traction Control and Map strategies via CAN inputs from the same bit is an option or if I need to come up with a different solution.
TC and Cal selector over CAN
Return to “S7-I / S7Plus Technical”
Jump to
- ↳ General Syvecs Chat
- ↳ S6 GP/PnP Technical
- ↳ S6-I / S6Plus Technical
- ↳ S7-I / S7Plus Technical
- ↳ S8 Technical
- ↳ S12 Technical
- ↳ Syvecs Bluetooth Module
- ↳ Software
- ↳ Calibrations
- ↳ Technical Deposit
- ↳ Projects
- General Technical Forums
- ↳ Subaru
- ↳ Mitsubishi
- ↳ Toyota
- ↳ Nissan
- ↳ Porsche
- ↳ Dyno Talk
- ↳ Track Days
- ↳ VAG Technical
- Expanders
- ↳ X10 (Legacy - Gen1)
- ↳ X10 Gen2 Expander
- ↳ X20L Gen2
- ↳ X4 Gen2
- ↳ OEX - Oem Ecu eXpander
- Syvecs AWD Modules
- ↳ General Questions
- ↳ Porsche 991.1 / 991.2
- ↳ Porsche 997.1 / 997.2
- ↳ Huracan / R8
- ↳ Nissan R35GTR
- ↳ Infiniti Q60
- ↳ Yaris GR
- ↳ CorollaGR
- ↳ Generic AWD Module
- ↳ Syvecs KT8
- ↳ Syvecs Wifi Module
- ↳ Syvecs WMI Module
- ↳ Syvecs DI12
- ↳ Syvecs Lam2CAN
- Syvecs Dashes
- ↳ Syvecs TinyDash
- ↳ Syvecs D5 Dash
- Enhancements
- ↳ Feature Requests
- ↳ Request for Comments
- JT Innovations
- ↳ Toucan Display
- ↳ General
- Feedback
- ↳ Website feedback
