Learn Maps - committing to base maps?
beetos
Post by beetos »
Hi
Does anyone know if the 'learn' maps (For idle base duty, knock/cylinder trim, WG duty etc) can be committed to their respective base map or do they just exist as separate constantly changing maps? Other ECU's I have used allow you to commit to the base map and zero out the learn map, wondered if you can do this on the syvecs.
Slowie
Re: Learn Maps - committing to base maps?
Post by Slowie »
Hi
When you are viewing the actual learning correction map (e.g. Base Wastegate Control Duty Learning / Learned Correction 1) you can use the Learn menu (top right) to apply or reset the learned correction to the base map.
beetos
Post by beetos »
Thank you! I missed that feature.
klakling
Post by klakling »
You can use the Learn menu (top right) to apply or reset the learned correction to the base map.
After covit, my need to travel is also growing. I mostly use the map to locate the best direction for myself classic games Spades
