Toucan set up
Basky
Toucan set up
Post by Basky »
Hi is there a toucan set up post
Fitted the toucan to s6 but says not connected to ecu.
Re: Toucan set up
User Guides on our website:
https://jti.uk.com/user-guides/
Also be aware of Toucan firmware version issues relating to the S6 (https://jti.uk.com/software-and-firmware/) if you are using RS232 - you need to use firmware older than V1.90
Usually, if you follow the User Guide to set up the datastream, it will "just work".
Basky
Re: Toucan set up
Post by Basky »
Great thank you 👍👍
Basky
Re: Toucan set up
Post by Basky »
On can 1m and still not reading ecu.
Grey wire is only wire not connected as im using cal switch
Canbus termination is off ?
Re: Toucan set up
Basky wrote: Sat Aug 21, 2021 7:02 pm Canbus termination is off ?
Obviously worth a try - technically it should be ON but if S6 and Toucan are the only devices on the bus it usually works.
Without more details it's rather difficult to advise - for example: new or second hand Toucan; has it ever worked; attach your CAL and I can check that it really is set up OK; second hand S6...possibly one of the 500 that didn't have CANbus, so have you tried RS232; what Toucan firmware version. And things like that.
Basky
Re: Toucan set up
Post by Basky »
Yes ive tried on and off with the canbus.
The toucan is new last week.i work away in the week so cant call help line as i cant be with the car.ive tried can1 and r232 and same results .
Not sure how post pics of the screens.
Have got whatsapp if possible to send through ?
Basky
Re: Toucan set up
Post by Basky »
V1.84a
Re: Toucan set up
That version (although not what new units ship with) is known to work OK.
Various possibilities:
- faulty/damaged cable
- mismatch between Toucan CAN datarate and S6 settings
- S6 datastream not set right (attach your cal file here or send it to us direct)
- Toucan cable plugged into Ethernet connector instead of comms connector
- if S6 PnP have seen problems with comms connector not soldered in very well or shorting on ecu case.
- Being S6 it is obviously an old unit; could be faulty perhaps?
Basky
Re: Toucan set up
Post by Basky »
So if the comms socket if damaged how would i find out ?
The cable is brand new so that is under warranty.
Failing all this i,ll return the toucan to jt.
Can the comms cable be hard wired in ?
Basky
Re: Toucan set up
Post by Basky »
All plugs in correct place.
Did a constituency test on ecu plug from toucan and all ok so cant be the loom.
Maybe the comms plug like you say tim.can this be repaired or hard wired ?
