Latest Base Map
Posted: Thu Mar 11, 2021 11:27 am
by Ryan.g
The latest Porsche 991 AWD Base map which matches the latest firmware can be found below in Attachments
1.15
Posted: Tue Apr 27, 2021 2:18 pm
by Ryan.g
1.15 Firmware base maps
1.18
Posted: Tue Oct 12, 2021 8:44 am
by Ryan.g
1.21 Base Map
Posted: Thu Nov 04, 2021 5:51 am
by Ryan.g
For use with 1.21 Firmware
1.23 Base Maps
Posted: Wed Jul 13, 2022 2:46 pm
by Ryan.g
For use with 1.23 Firmwares
1.24 Base Maps
Posted: Fri Nov 25, 2022 12:17 pm
by Ryan.g
For use with 1.24 Firmwares
1.25
Posted: Fri Apr 07, 2023 7:05 pm
by Ryan.g
Re: Latest Base Map
Posted: Fri Dec 15, 2023 5:51 am
by Ryan.g
For use with 1.27 Firmwares
Re: Latest Base Map
Posted: Mon Apr 15, 2024 3:00 pm
by Ryan.g
For use with 1.28 Firmwares
Re: Latest Base Map
Posted: Fri Apr 19, 2024 1:08 pm
by Ryan.g
1.29 Base map
