firing order
Posted: Mon May 14, 2018 1:54 pm
by davecarroll
Hi Guys,
A simple question: what is the correct way to wire up ignition coils, when wired direct to the Syvecs?
My firing order table is as follows:
Ign Output: 1 2 3 4 5 6
Firing Order: 1 5 3 6 2 4
Does the syvecs fire the ign outputs in sequence and I need to wire each output to the firing order?
Or does the syvecs fire the ign outputs to the firing order so I wire the ign outputs in cylinder order?
Basically, should I wire ign1 to cyl 1, ign 2 to cyl 5 etc....
or, ign 1 to cyl 1, ign 2 to cyl 2 etc...
Thanks guys.
Dave
Re: firing order
Posted: Mon May 14, 2018 8:32 pm
by davecarroll
Solved:
The ecu can run either in sequence or firing order using the firing order in combination with the i/o settings for the ign outputs.
I should have used the search button better in the firat place!!
