Page 3 of 5
Re: new to all of this
Posted: Fri Aug 24, 2012 11:04 pm
hagar wrote:where is ryans manual?
In the "Technical Deposit" section :)
Posted: Fri Aug 24, 2012 11:23 pm
by hagar
and the bigger problem, do i use the original ignitor box or does the syvecs take care of it?
Posted: Sat Aug 25, 2012 6:46 am
If you look in Ryan's manual....
"The ignition channels are logic level outputs designed to control ignition coils via an additional igniter
(Power transistor). These as standard output a 5V Signal but can be raised to 12v with a Jumper change
on board. Speak to Syvecs more about this directly if required"
Posted: Sat Aug 25, 2012 6:00 pm
by pavlo
If the 12v output is used it is still LOW CURRENT and cannot drive a coil, but some CDI units of old need a 12v trigger to work effectively so the function does have it's uses.
Posted: Tue Aug 28, 2012 9:15 pm
by hagar
well i'm putting it into a 92 mk3 1jz gte supra import. how can i find out the voltage they require to fire. i can't find it in the literature i have and i cannot read japanese. there may or may not be jumpers on my syvecs but it is riveted shut and i cannot see the board so how will i know.
Posted: Tue Aug 28, 2012 10:07 pm
by pavlo
I would assume 5v will be fine. But the ignition output will go to the ignition amp, not the coil. I've yet to find an application myself that the normal 5v doesn't work on.
Posted: Tue Aug 28, 2012 10:50 pm
by hagar
it was the ign amp i was talking about.
Posted: Wed Aug 29, 2012 12:45 pm
by pavlo
yup 5v will be fine I'm sure
Posted: Wed Jan 09, 2013 4:53 pm
by hagar
is there a downloadable map just to start the car and to get it to tick over as i will no doubt have a few water/oil leaks to sort out and it will need a oil change before any thought of tuning and MOTing it? i need to get her warm.
Posted: Wed Jan 09, 2013 5:09 pm
by pavlo
That will depend on your wiring loom!
The calibration will need to be matched to suit the wiring, and then the sensors calibrated to some degree and then one can take a stab at a map that will get the thing running, but really you need at very least a lambda sensor on it.
Your best bet at this point is to get a tuner to come to you that can very quickly get you up and running.
