I've unassigned it from SWA, but if I try to assign it to CAM EXH VVT, I see Pin does not support the required input config when I try to program the ECU.
I've set the Cam Sensor Type to Thermistor, Input Filter ON, High Trigger 3V, Lo Trigger 2V, and Rising Edge, which is the same config as the sensor used on the Inlet VVT sensor.
Is it that the Input I'm using doesnt support Thermistor so I need to choose a different input altogether? It is labelled as (GEN) which I thought meant it was 'all of the above' , ie 5V/TH/BI/FREQ
If instead I just chose 5V for the sensor, which is how it was used when it was the Steering Wheel Angle input, will the cam sensor work reliably?
[edit] I tried settting the sensor to 5V and I stll get the Pin does not support message
