Hi, this is my first post on this forum. I should start out by saying that I am using a Life Racing F88RS. I have found this forum and your YouTube channel a big help in getting running on the F88 as there is virtually no documentation about this unit and Life have not replied to any of my email questions.
I now have a question where I cannot find the answer - as the F88 and Syvecs are so closely related I thought I would post my question here in the hope that one of the experts on this forum can help.
I'm running a Shiftec Air Power Source ( pneumatic compressor ) for my shift system. The Shiftec unit sends out a number of CAN messages on the status of the unit and in particular I am interested in receiving the System Pressure value in the ECU for logging purposes.
I've setup the Custom CAN, created a User Defined variable ( with appropriate scaling ) and used the I/O Configuration to set this to a particular CAN message. I am receiving data but the issue is that once the pressure goes beyond half scale of the parameter ( 6.4 bar in this case as full scale is 12.8 bar ) then the value turns negative.
It would seem that the ECU is expecting the CAN message to be 'Signed' whereas in fact the Shiftec is sending an 'Unsigned' message. I have looked through all the parameters within LifeCal and can't find anyway to change to an Unsigned message. Can you offer some advice and point me in the right direction?
Ian
CAN Receive
Re: CAN Receive
hi
I just had this issue with a s7 plus the other week .
My fix was get the product designer (shiftec in your position ? )to modify the can setup to match signed as that what the ecu wants to see .
It now works fine .
It now works fine .
Re: CAN Receive
Thanks for the reply. I suppose it is good that I haven't missed anything obvious, however I'm not sure how viable it will be for Shiftec to provide me with a custom firmware for the unit with a new CAN config.
My other plan was to get up to speed with Arduinos and use one of these to manipulate the CAN messages myself. This may be a better long term solution.
The system pressure is typically above 6.4 bar most of the time, so at the moment I have a work around of adding a constant 12.8 bar to the output so most of the time it reads right but then if it drops below 6.4 it will read around 19 bar.
Ian
Ian
Re: CAN Receive
I have just installed a ecu master v3 and thats working perfect .
i am sure they will do a firwmware update to match a ecus datastream setup .
pm me if you need any help
regards
gaz
regards
gaz
Re: CAN Receive
Guess the $1m question is whether the ECU vendor should allow loads of flexibility in CAN configuration to allow you to match the setup to 3rd party equipment, or if the 3rd part equipment vendor should adjust their CAN data to match the ECU's demands.
Discuss
Discuss
Re: CAN Receive
If the ecu supplier does not offer similar product...why not encourage external devices to be easily usable with that ecu, which can only enhance the user experience of the ecu ?
And the easier it is to use, the more people would be willing to use it etc.
But true, at the same time, those makers of external devices should be able to cater their universal product, to the wide range of ecu's people may wish to use their product with.
Re: CAN Receive
Hey Stevie,
Send me an email at info@shiftec.com and I'll pop it into our support system to see if we can help!
Thanks (and thanks for using our products!)
Brett
PS yes I did make an account just to reply to this!
Brett
Re: CAN Receive
brettshiftec wrote: ↑Fri May 29, 2020 12:16 pm Hey Stevie,
Brett
Good stuff, but I believe it was Ian asking originally.
Re: CAN Receive
Oops, it was Friday, I'll blame that!stevieturbo wrote: ↑Fri May 29, 2020 2:32 pmbrettshiftec wrote: ↑Fri May 29, 2020 12:16 pm Hey Stevie,
Brett
Re: CAN Receive
Thanks for the reply Brett. The problem is not the end of the world as it works 99% of the time. I've contacted your support in the past in order to get the CAN message details from the APS.
Now that trackdays are back on, I can get the car on track and start calibrating the shifts. If the CAN messages become a real problem then I'll drop you an email.
Ian
Ian
