I need some help to solve the errors mentioned below.
I already made some search to try to find solution, but without success for the moment.
I've rechecked several times my IO Pinout on the wiring and in SCal. The sensors are attached to their connector and wiring is OK from the sensor connector to engine connector. Then the OEM loom from engine connector to ECU connector is untouched.
I just want to say that I modified a GDB engine loom to fit the original GC8 loom without modification on this one.
I can't understand how to solve those errors. Thanks for your help
